Authentication problems after changing password
Problem
After I changed the password in my Institutional Gmail I have to re-authenticate every time I restart the PC. This error is reported in the config log file:
*** {“debuginfo”:“https://www.googleapis.com/oauth2/v4/token RETURNED {\n “error”: “invalid_grant”,\n “error_description”: “Bad Request”\n}”,“key”:“Invalid Response Code: 400”,“retryable”:false,“what”:“Unknown exception”}
The problem returns every time I restart the System.
Email Provider
Gmail
Mailspring Version 1.9.1
  • OS and Version: Windows 10 Pro, Version 20H2
    • Installation Method: installer 64xbit
  • Mailspring Version: 1.9.1
This is happening for me also on a hotmail account, using Windows 10 1.91 aswell.
Tried to delete the account and add again, but it didn’t solve.
This is happening to me as well - changed passwords on two Google accounts and I keep having to reconnect both after each system restart.
Mailspring 1.9.1, Windows 10 Home build 19042.
I have the same problem.
Every time I turn on the notebook, I need to reauthenticate my hotmail.
I’ve logged out and logged in again, but it doesn’t work.
print error mailspring
For hotmail, i would highly suggest using a application specific password for malspring and use a real 2FA for your account.
Following this link will generate a applicaiton specific password that you can use as hotmail password in Mailspring : https://account.live.com/proofs/AppPassword
