Can't connect Yandex accounts
Can’t add Yandex accounts.
  1. Created app Password, Enabled IMAP
  2. Mailspring can’t authorize
  • Windows 11
    • Installation Method: installer
  • Mailspring Version: 1.9.2
Error Log I got:
Important: You must enable IMAP and you may need to link a phone number to connect to your Yandex account. If you use two-factor auth, you must create an App Password for Mailspring.
https://mail.yandex.com/#setup/client
Waiting for Account JSON:
Waiting for Identity JSON:
info: Identity created at 1641816398 - using ID Schema 1
OPENSSL_Uplink(5D0DD878,08): no OPENSSL_Applink
There’s no need for app password AFAIK. It’s just IMAP with the right settings but anyway when adding an account, you just select Yandex.Mail…
No?
