system
(system)
January 17, 2021, 3:20am
#1
opened 05:39AM - 01 Aug 20 UTC
closed 11:37PM - 16 Aug 20 UTC
----------IMAP----------
connect mailcore::IMAPSession:0x7ffddcf1e4e0
OK Yandex IMAP4rev1 at sas2-1e59ad28a72c.qloud-c.yandex.net:993 ready to talk with ::ffff:89.222.174.138:38922, 2020-Aug-01 08:34:38, cYXlpv732Cg1
ssl connect imap.yandex.com 993 2
OpenSSL version: OpenSSL 1.1.0f...
bug
OpenSSL version: OpenSSL 1.1.0f 25 May 2017
1 CAPABILITY
CAPABILITY IMAP4rev1 CHILDREN UNSELECT LITERAL+ NAMESPACE XLIST BINARY UIDPLUS ENABLE ID AUTH=PLAIN AUTH=XOAUTH2 IDLE MOVE
1 OK CAPABILITY Completed.
connect ok
login
2 LOGIN "******@yandex.ru" *********
2 NO [AUTHENTICATIONFAILED] LOGIN invalid credentials or IMAP is disabled sc=cYXlpv732Cg1_010534_2-1e59ad28a72c
Fedora 32
Mailspring Version: 1.7.8-13635bcfstrong text
(Originally posted by bazhenovrussia on GitHub.)
bengotow
(Ben Gotow)
January 17, 2021, 3:22am
#2
Visit Yandex.Mail — free, reliable email and make sure you’ve checked “enable IMAP” on that screen. You may also need to create an app password for Mailspring depending on the options you choose on that page.
system
(system)
January 17, 2021, 3:24am
#3
Still the same problem with me and yes I enabled the IMAP.
(Originally posted by Minashraf on GitHub.)
system
(system)
January 17, 2021, 3:31am
#4
The problem is, that we can’t use our normal yandex password. Go to https://passport.yandex.com/profile/ and create new app password for mail and then use it as your password in mainspring. Worked for me.
(Originally posted by simon-the-shark on GitHub)
Oleshko_G
(Gennadiy)
March 25, 2022, 8:03am
#5
It works for a time. In a week it happens AGAIN. It’s EXTREMELY FRUSTRATING!
