Infinitely "Working..." with no other feedback
The software is stuck on the “Working…” screen on first-time setup.
  1. snap run mailspring
  2. Get Started
  3. Next x3
  4. Just need the basics? Skip for now
  5. Skip Mailspring ID
I expected to be able to use Mailspring as I’ve done in the past.
  • OS and Version: Linux 5.16.14-1-MANJARO
    • Installation Method: snapcraft
  • Mailspring Version: 1.10.1
Logs:
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
Gtk-Message: 01:47:47.498: Failed to load module "xapp-gtk3-module"
Gtk-Message: 01:47:47.525: Failed to load module "canberra-gtk-module"
Gtk-Message: 01:47:47.526: Failed to load module "canberra-gtk-module"
Running database migrations
App load time: 148ms
{"error":null}
(node:23372) electron: The default of nativeWindowOpen is deprecated and will be changing from false to true in Electron 15.  See https://github.com/electron/electron/issues/28511 for more information.
(Use `mailspring --trace-warnings ...` to show where the warning was created)
(mailspring:23372): GLib-GIO-CRITICAL **: 01:47:52.053: g_dbus_proxy_new: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
