I agree. This plugin alone makes a huge difference. It should be a default feature.
I have exactly the same problem with my application, I am in version 1.9.2
installed the v1.2, from me it works on v 1.9.2 !
Iâll love to have higher resolution avatar, but its better than nothing
how can i remove it ? i have V1.9.2 i installed the V1.2
hello,
how to remove the plugin ?
thanks
Just have the same problem: https://github.com/Foundry376/Mailspring/issues/649, for me it was placed in ~/.config/Mailspring/packages
cheers
I like the idea of this plugin, but I have two issues with it that I could not resolve myself:
- With certain window sizes the avatars are not just shown once, but twice for each message. As if both small and large avatar are triggered simultaneously. Making my window bigger avoids the issue, but I donât want to do this
- Resizing the window triggers mailspring to re-fetch all gravatars that previously failed to fetch. These â404 - File Not Foundâ results should probably be cached somehow to avoid excessive requests to gravatar.com.
Hi there,
So did we find the fix for the issue?
Issue finally resolved ! Sorry for the long wait
Thanks also to all of you for your contributions which allowed me to progress in my debug! I was able to reproduce the bug with a little luck
New release : 1.3.0
Whatâs up ?
- Query avatars from multiple sources (#5 & #6) (thanks @avelino !)
- Improve avatars sources order (#7)
- Fix duplicate images (#8) (thanks everyone, especially @andybrice !)
- Fit avatars with object-fit: cover (#9)
- Upgrade node libraries (#10)
Full changelog : 1.2.0âŠ1.3.0
Direct download : mailspring-avatars-1.3.0.zip
Thanks for your feedback.
- The problem of duplicate images has been solved in the last release.
- I havenât found any solution to prevent 404 errors display in the console. If someone has an idea how to do this Iâm interested
This is awesome! Itâs so much easier to go through my emails and locate emails that I WANT to read. Thanks for this one!
Thanks for this plugin. For me, this was the only big feature I was missing in vanilla Mailspring.
Iâm happy to find out that you created a solution for this! Works great in the current version of Mailspring (1.11.0).
New release : 1.4.0
Whatâs up ?
- Get background color based on senderâs e-mail address (no more randomize) (#12 )
- Limit initials length to 3 characters (#11)
Full changelog : 1.3.0âŠ1.4.0
Direct download : mailspring-avatars-1.4.0.zip
This is awesome, thanks a lot! Works like a breeze and looks great on the less is more theme.
I did it with Windows, but may help.
In mailspring-avatars>styles>index.less file, I changed top to 20px
.thread-injected-mail-labels {
.thread-avatar{
margin: 1px;
position: fixed !important;
top: 20px;
left: 7px;
transform: translate3d(0, 0px, 0px) scale(.8);
transition: all .15s cubic-bezier(0.35, 0.91, 0.41, 0.99);
