Problem with libsecret - org.freedesktop.secrets
I use archlinux with kde / plasma, as kwallet still doesn’t support org.freedesktop.secrets, I’m using KeepassXC, because I don’t want to use gnome-keyring …
It seems that Mailspring cannot use dbus communication with KeepassXC.
  1. Install KeePassXC
  2. enable integration in KeePassXC with org.freedesktop.secrets
  3. open Mailspring
  4. Mailspring could not store your password, make sure you have libsecret
be able to use any program that provides the org.freedesktop.secrets service
  • OS and Version: archlinux - kde/plasma 5.20
  • Mailspring Version: 1.7.8, 1.8.0
It should be noted that I have other programs that depend on org.freedesktop.secrets, such as MySQL Workbench which works well with KeePassXC
PD
I have been able to solve it, it seems that you have to expose a group and associate it to the org.freedesktop.secrets service
more info here. in the KeePassxc part
@wcasanova Thanks for letting us know, that you were able to resolve the issue yourself. I am going to lock the issue.
