Selected message does not advance on first key press
I’ve recently noticed some odd behaviour while navigating my messages. When I press down, it goes to the previous message immediately. When I press up once nothing happens. A second press of the up cursor key will advance it to the next message. Any subsequent presses of the up cursor key advance by one message. The same behaviour occurs using j and k.
  1. Go to any folder.
  2. Use the keyboard to select previous message
  3. Use the keyboard to select next message
  4. Message selected does not advance
  5. Use the keyboard to select next message
  6. Message selected advances
Message selected should advance with each press of hotkey (Up or k)
  • OS and Version: Linux Mint 19.3
    • Installation Method: package manager (apt)
  • Mailspring Version: 1.9.1
