As a workaround, you may try to set the spellcheck to a different flavour than your system language. E.g. when your system is configured to use “en-US” as a language and provides its dictionary, then “en-GB” might work.
I will monitor the issue and hope that a solution is possible in the future. For now, there is not much that we can do on the side of Mailspring.
Thanks for this reply. It doesn’t solve the problem, but it gives hope that you will eventually fix it. This is the main blocker against the decision to go for the paid version (although the price is also a bit too high, $5 would be a reasonable barrier - for example, the whole Google Workspace costs $6/month) . Maybe some kind of -50% promo on BFCM? I would jump into the annual package hoping that you will soon fix the bug with the lack of language correction.
An idea - maybe there is a chance to make a plugin for Mailspring that would use LanguageTool API documentation ?
I’m not a programmer, so I have no idea if it is or isn’t possible to create a spell checker plugin
However, I have seen the obsidian.md plugin, so I assume it is possible.
Really one of best email clients, which I tested, but this issue is making me step of uninstall it and forgot. How to pay for soft without this basic function?
However, I hope that this can somehow be fixed soon.
This does seem to work on Windows 10. I have my system set to use “en-US” and when going into mailspring preferences and setting my spellcheck language to use “en-United Kingdom” the spellcheck then seems to function properly.
I am running version 1.13.1-59cb1b1d
Hopefully, this bug can get fixed soon but it doesn’t seem likely. Thank you for the temporary workaround though.
