Difficult to input text when typing email body
When Enable rich text and advanced editor features is open, in the Send Email Window, typing Chinese text is difficult.
  1. Enable Enable rich text and advanced editor features in Settings.
  2. Open Send Email Window.
  3. Type something in email body using any Chinese Input Method.
For Example, I type ‘ni’ but turn to ‘i’. And then Input Method disappear.
For reference, this is what normal typing looks like.
PixPin_2026-10-12_21-26-21
But in Mailspring…
PixPin_2026-10-12_21-29-22
  • OS and Version: Windows 11 26H2
  • Mailspring Version: 1.26.0-3b46a5b1
In fact, related reports emerged years ago, but the problem still appears unresolved.
The fix has been merged ( Don't toggle spellcheck while an IME composition is in progress by AlexandreAgrn · Pull Request #2990 · Foundry376/Mailspring · GitHub ) and should ship in the next release. Until then, turning off “Check messages for spelling” in Preferences > General should work around it. If you get a chance to confirm that it does on Windows, that would help: I could only verify the mechanism on macOS.
