TAGS: dark mode, on-boarding, search, smart folders, interface
Failure for me. It was too difficulty top get past on-boarding and that needs to be fixed. Allow it to be canceled. A waste of time when someone wants to see the application first.
No dark mode at startup, causing near blindness. It should match the system theme by default!!!
To be fair, many devs screw this up, but when you’re forcing on-boarding, so you can’t skip it, it’s painful. Even editing the json file and forcing dark mode there doesn’t work at all in on-boarding. It’s all 1000 lumens.
Once getting past the initial problems, and being able to test the application, the deal killer was no saved searches or smart folders.
Also, no option to turn on the menu bar. Even Evolution can do that.
Hopefully, some day. The rest looks pretty good, and now in the future, I know what to look for before trying again.
The interface problems, could be worked around. Although a massive, frustrating waste of time, the on-boarding lock could be worked around. Those would be nice to have fixed, but the no searching and smart folders is a deal-breaker.
Thanks, I hope feedback helps.
