Mailspring don't start correctly
  • OS and Version: SOLUS 4.3 Budgie 10.6.1
    • Installation Method: eopkg (SOLUS database)
  • Mailspring Version: 1.10.3-a476c230 (as seen in mailspring --version)
Since the last update to budgie 10.6.1 mailspring starts correctly 1 out 10 times , and also it “slows down” my mining via CPU with xmrig , if i “kill” the program and start it manually the “slowing down” isn’t found any more. Same thing i discover if i disable the auto start from within and create custom auto start as: mailspring -b , the program starts correctly . Also it doesn’t “slow down” my hashrate with xmrig if i start it that way.
EDIT: After some reboots i found that the problem persists , uninstalled mailspring and installed snap version while copying my profile from legacy installation to snap , now it start every time without any problem (of course i added the mailspring -b to auto start of my solus)
