Cursor not scrolled into the view when replying to a message
Cursor is not scrolled into the view when replying to a long message with the options for plain text editor and chronological conversation order enabled.
  1. Go to Preferences
  2. Enable Display conversations in descending chronological order
  3. Disable Enable rich text and advanced editor functions
  4. Go to Inbox and open a long message (which doesn’t fit in the screen)
  5. Click on Write a reply
  6. The cursor won’t be scrolled into the view.
  • OS and Version: Ubuntu 20.04
  • Mailspring Version: 1.7.8
(Originally posted by asparc on GitHub.)
