I just installed Mailspring on Fedora 33 and am stuck in the welcome flow. After the 3rd tip it briefly shows a small loading indicator and then just a white screen. The back button at the top-left is still working, so it didn’t crash and I can go back and try again, but I cannot progress past this point.
- Start fresh Mailspring installation
- Click “First steps” (I presume that’s what it says in English)
- Click “Next” three times
- End up at a white screen
It should allow me to finish the welcome flow.
- Linux 5.10.22-200.fc33.x86_64
- Fedora 33, GNOME Shell 3.38.3 under Wayland
- Installed using the RPM from GitHub
- Mailspring 1.8.0-8983dca2
Log output
Fontconfig warning: "/usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf", line 6: unknown element "reset-dirs"
Running database migrations
App load time: 160ms
{"error":null}
Manual update check (updates.getmailspring.com/check/linux/x64/1.8.0-8983dca2/anonymous/stable) returned 503
Error Downloading Update: Unexpected end of JSON input
