I usually send my emails with signatures that go like
Regards,
ARTman
But in Mailspring, I can’t make it like that. It’s either the templates, or Raw HTML.
A simple Text Editor option similar to Thunderbird or even Gmail itself, where I can add my signature in the way I want. You could even implement the text box similar to the text box on the community…
Alternative Solutions
As of now, only Raw HTML is present, which is fine but I don’t want to have to look up how to write in HTML for something as simple as my signature.
