Antivirus detected a virus JS.Siggen5.44590
My antivirus detected a virus in the application downloaded from the website.
  1. Download the app from the website
  2. Check it for viruses with Dr.Web antivirus
  3. Done
  • OS and Version: macOS Sequoia 15.4.1
  • Installation Method: Unpacking from zip archive
  • Mailspring Version: Version: 1.15.1
  • Time zone: Moscow
Hi Alexey,
Thanks for reporting this. This is a false positive and your installation is safe.
What’s Happening
Dr.Web’s JS.Siggen5.44590 signature is flagging the es5-ext npm package, which is a transitive dependency in Mailspring. This package contains what’s known as “protestware” - it includes a postinstall script that displays an anti-war message to users whose system timezone is set to a Russian timezone.
The code does not:
  • Steal data
  • Modify files
  • Perform any malicious actions
It simply prints a message during npm installation (which doesn’t even run in the packaged app you downloaded).
Why Russian Antivirus Software Flags It
Several Russian antivirus vendors (including Dr.Web and Kaspersky) have incorrectly classified this package as malware. The maintainer of es5-ext has documented this issue: GitHub Issue #186
What You Can Do
  1. Add an exception in Dr.Web for Mailspring - it’s safe
  2. Report the false positive to Dr.Web if you’d like to help them improve their detection
The Mailspring codebase is open source and you can verify there’s no malicious code: GitHub - Foundry376/Mailspring: 💌 A beautiful, fast and fully open source mail client for Mac, Windows and Linux.
This is a known issue affecting many Electron apps that use es5-ext as a dependency. The security research community has documented this extensively - see Checkmarx’s analysis which confirms the code is protestware, not malware.
Let me know if you have any other questions!
Yep I mentioned this in a similar post. Only Dr.Web marks it as a “virus”. You did a better job explaining it than my quick Google search on the topic previously: Virus Trojan JS.Siggen5.44590‌ on Mailspring Pro Piad version - #2 by compuguy
