Applying labels require mouse or arrow keys
Just updated to Version 1.18.0-d5199390 and found that when adding labels using the gmail keybindings, pressing “l” works to bring up the label search, and I can type, but the box does not ‘auto-select’ the first item, so hitting enter does not work until either using the down arrow key or using the mouse to click on the option.
  1. Verify using gmail keybindings
  2. Select email
  3. use the “change labels” shortcut (gmail lowercase L)
  4. Search for a label by typing the name
  5. Press enter does not auto-select the top item
Expected to auto-select the top label when searching and pressing enter (or if search result does not return anything, hitting enter will create a new label)
  • OS and Version: Fedora Workstation 43
    • Installation Method: flatpak
  • Mailspring Version: 1.18.0-d5199390
appears to be resolved in 1.19.0-29769fad
