Is it possible to disable automatic numbering and bullet point lists?
Best regards,
DS
Best regards,
DS
There’s no switch for just that behavior, but the trigger is narrow: the composer only converts a line into a list when you type - or 1. (dash-space or one-dot-space) at the very start of a line. Anything else — 2., a), *, a dash mid-sentence — is left alone, so if you need a literal "1. " at the start of a line you can type the text first and add the 1. afterwards, or put a space or other character before it.
If you’d rather have no automatic formatting at all, plain-text mode turns off lists and the rest of the rich-text features: uncheck Enable rich text and advanced editor features in Preferences > General > Composing, or hold Alt (Option on Mac) while clicking Compose or Reply to make a single plain-text draft.
