Is there syntax documented somewhere for how to use NOT in a search? If I want to look for a message from Code Mouse that is not in my forums folder, how would I phrase that?
Good news! Yep, this is there, although it isn’t well documented.
The NOT operator works much the same as AND or OR does, although it’s a touch odd/unpredictable in places. (Feature request?)
For example, if I want all my emails with the subject “DEV Report”, but not in my “Archive/2020” folder, I’d use the following:
subject:"DEV Report" AND NOT in:Archive/2020
@amandabee So, your query would probably look like this:
