Breeze-Light theme (Tela Icons)
A theme based on the Breeze theme for Plasma KDE, using the default light colors. Icons from Tela (a version with default Breeze icons can be easily made if there is some request)
You can clone the repository on github
    git clone https://github.com/paulatz/Mailspring-Theme-Breeze-Light
or download the zip package and decompress it anywhere. In any case, just use the Add Theme of Mailspring and select the theme directory.
For some reason I’m not able to edit the post. So here is an update: the theme now comes with both Tela and Breeze icons, you can easily change the ones used as explained in the github page
I have installed this theme but I have lost the ability to change the theme. How can I see the “Install new theme” option again?
Just thought I’d add a note to my question to say I worked out how to change the theme and have changed back to Matcha theme(which is my current favourite)
