As mentioned here I have node: v16.13.2 and npm: 8.1.2
After running npm install I get the following output:
> mailspring-root@0.0.1 postinstall
> node scripts/postinstall.js
-- Clearing app/node_modules (false !== 8.5.5) --
-- Running npm install --no-audit in ./app with electron config --
npm ERR! code 1
npm ERR! path /home/jirka/Programs/Mailspring/app/node_modules/cld
npm ERR! command failed
npm ERR! command sh -c node-gyp rebuild
npm ERR! make: Entering directory '/home/jirka/Programs/Mailspring/app/node_modules/cld/build'
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cldutil.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cldutil_shared.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/compact_lang_det.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/compact_lang_det_hint_code.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/compact_lang_det_impl.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/debug.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/fixunicodevalue.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/generated_entities.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/generated_language.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/generated_ulscript.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/getonescriptspan.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/lang_script.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/offsetmap.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/scoreonescriptspan.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/tote.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/utf8statetable.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld_generated_cjk_uni_prop_80.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_cjk_compatible.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld_generated_cjk_delta_bi_32.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/generated_distinct_bi_0.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_quad0122.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_deltaocta0122.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_deltaoctachrome.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_distinctocta0122.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_distinctoctachrome.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_quadchrome_16.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld2_generated_quadchrome_2.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld_generated_score_quad_octa_0122.o
npm ERR! CXX(target) Release/obj.target/cld-c/deps/cld/internal/cld_generated_score_quad_octa_2.o
npm ERR! AR(target) Release/obj.target/deps/cld/cld-c.a
npm ERR! COPY Release/cld-c.a
npm ERR! CXX(target) Release/obj.target/cld/src/constants.o
npm ERR! CXX(target) Release/obj.target/cld/src/cld.o
npm ERR! make: Leaving directory '/home/jirka/Programs/Mailspring/app/node_modules/cld/build'
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@7.1.2
npm ERR! gyp info using node@16.13.2 | linux | x64
npm ERR! gyp info find Python using Python version 3.10.1 found at "/usr/bin/python3"
npm ERR! (node:85531) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/home/jirka/Programs/Mailspring/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/home/jirka/Programs/Mailspring/app/node_modules/cld/build/config.gypi',
npm ERR! gyp info spawn args '/home/jirka/Programs/Mailspring/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/home/jirka/.cache/node-gyp/8.5.5/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/home/jirka/.cache/node-gyp/8.5.5',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/home/jirka/Programs/Mailspring/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=/home/jirka/.cache/node-gyp/8.5.5/<(target_arch)/node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/jirka/Programs/Mailspring/app/node_modules/cld',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! ../src/cld.cc:5:12: error: ‘terminate_handler’ has not been declared in ‘std’
npm ERR! 5 | using std::terminate_handler;
npm ERR! | ^~~~~~~~~~~~~~~~~
npm ERR! ../src/cld.cc:6:12: error: ‘unexpected_handler’ has not been declared in ‘std’
npm ERR! 6 | using std::unexpected_handler;
npm ERR! | ^~~~~~~~~~~~~~~~~~
npm ERR! make: *** [cld.target.mk:113: Release/obj.target/cld/src/cld.o] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/home/jirka/Programs/Mailspring/node_modules/node-gyp/lib/build.js:194:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:390:28)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
npm ERR! gyp ERR! System Linux 5.16.1-zen1-1-zen
npm ERR! gyp ERR! command "/home/jirka/.nvm/versions/node/v16.13.2/bin/node" "/home/jirka/Programs/Mailspring/node_modules/.bin/node-gyp" "rebuild"
npm ERR! gyp ERR! cwd /home/jirka/Programs/Mailspring/app/node_modules/cld
npm ERR! gyp ERR! node -v v16.13.2
npm ERR! gyp ERR! node-gyp -v v7.1.2
npm ERR! gyp ERR! not ok
npm ERR! A complete log of this run can be found in:
npm ERR! /home/jirka/.npm/_logs/2022-01-20T17_49_03_335Z-debug.log
safeExec: the command exited with Error: Command failed: npm install --no-audit
npm ERR! code 1
1
`------------- stderr ------------
npm ERR! code 1
`------------- stdout ------------
npm ERR! code 1
npm ERR! command sh -c node scripts/postinstall.js
npm ERR! /home/jirka/.npm/_logs/2022-01-20T17_49_03_573Z-debug.log
I don’t know what to do at thsi point
