Is there a way to bypass this “error”? I need to add a lot of accounts to mailspring but i get the message that mailspring cannot store my password safely and redirect me to this thread: Password Management Error where it says “Windows has severe restrictions on the amount of data we can securely store. Since we store secure data for each email account you have, we’ve found once you link more than a dozen or so email accounts, we can approach the limit of the Windows password manager.” I tried this fix: Credential limit per app | Microsoft Docs but I get the same message from mailspring when I try to add another email account. Or is there another free email client that has an unified inbox and can manage a lot of accounts? I use bluemail but it gets laggy using it with multiple accounts.
That limit is gone. The “dozen or so accounts” ceiling came from the Windows Credential Manager, where each account’s IMAP, SMTP and OAuth secrets were stored as separate entries and Windows caps how much a single app can keep there. Since Mailspring 1.12.0 (October 2023) the app no longer uses the Credential Manager at all - every account’s secrets are packed into one encrypted value in Mailspring’s own config.json, encrypted with the Windows user-account key via Electron’s safeStorage. There’s no per-account entry and no limit on how many accounts you can add.
If you’re on a current 1.24.x build, you can link as many accounts as you like and they all land in the unified inbox (Setting up multiple accounts — Mailspring Documentation). The one thing you’ll see with more than four accounts on the free plan is a dismissable “please consider Mailspring Pro” notice - it doesn’t block anything.
