Changing expired password Error Code: 296
IMAP password for externl programs expired. Generated new one and put into mailspring:
mailsmtp Last Error Code: 296
mailsmtp Last Error Explanation: Unknown
mailsmtp Last Auth Type: 2
  1. add account with IMAP password for external program (i use ukr.net)
  2. password expired and generated a new one
  3. set the new password into mailspring
  4. mailsmtp Last Error Code: 296
should work normal with the new password
  • OS and Version: Windows 11 Pro 25H2
    • Installation Method: official image
  • Mailspring Version: 1.17.2
same password works well adding account to a browser mail
looks like same/similar to: Problem with SMTP login on version 1.17.2 Windows
have found this in config.json:
“syncState”: “invalid”,
“syncError”: {
“code”: 3221226505,
“error”: {
“stack”: “Error: null24872 [2026-01-28 09:35:39.874] [background] [critical] \r\n***\r\n*** Mailspring Sync \r\n*** An exception occurred during program execution: \r\n*** {“debuginfo”:“syncFoldersAndLabels - fetchAllFolders”,“key”:“ErrorAuthentication”,“offline”:false,“retryable”:false,“what”:“Unknown exception”}\r\n***\r\n\r\r\n\n at ChildProcess.onStreamCloseOrExit (file:///C:/Users/RUNNER~1/AppData/Local/Temp/nylas-build/electron-packager/tmp-n92MG5/resources/app/src/mailsync-process.ts:346:17)\n at ChildProcess.emit (node:events:519:28)\n at ChildProcess.emit (node:domain:489:12)\n at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)”,
“message”: “null24872 [2026-01-28 09:35:39.874] [background] [critical] \r\n***\r\n*** Mailspring Sync \r\n*** An exception occurred during program execution: \r\n*** {“debuginfo”:“syncFoldersAndLabels - fetchAllFolders”,“key”:“ErrorAuthentication”,“offline”:false,“retryable”:false,“what”:“Unknown exception”}\r\n***\r\n\r\r\n”
“signal”: null
and this ni logs:
29604 [2026-01-27 20:07:31.337] [foreground] [info] -X An SMTP error occurred: ErrorAuthentication LibEtPan code: 296
29604 [2026-01-27 20:07:31.367] [foreground] [error] [local-a27d9f31-2111] – Failed ({“debuginfo”:“ErrorAuthentication”,“key”:“send-failed”,“offline”:false,“retryable”:false,“what”:“Unknown exception”}). Changing status to complete
removing and adding account did not help (actually can not add the account because of the error)
switching to another ISP did not help
also, i think, you still need to allow adding an account if SMTP error or even SMTP is empty, i think it is helpful to have read-only accounts if required and which should not send any mails
works after updating to 1.17.3 version
but of course it is not guaranteed to be fixed and needs to be checked/tested.
This SMTP authentication issue was introduced in v1.17.2 and fixed in v1.17.3. Please update to the latest version (v1.21.1 as of May 19, 2026) — SMTP should work correctly. If you’re still seeing Error 296 on a current version, please reply with your provider and Mailspring version and we’ll investigate.
