Connection issue when try to use Yandex app password
Hello,
I am trying to connect to Yandex account with using Yandex App Password. When I create new account on “Accounts” tab, everthing is just fine. I can connect and use my Yandex account with no problem.
But when I reboot my desktop, Mailspring pop-up “Several of your accounts are having issues” and cannot connect to the account even if I push “Check Again” button.
The interesting thing is, when I go to “Reconnect” panel and try to connect with putting “same” app password, Mailspring connect the account and I use it as normal.
I am using Windows 10, doesn’t change app password when I try to reconnect and after reconnected with same password, everthing is running fine.
What is the problem and how can I fix that issue?
Here is the error details:
Mailspring Version: 1.9.2-6e14dad1
Platform: win32
Account State: sync_error
Account Provider: yandex
IMAP Server: imap.yandex.com
SMTP Server: smtp.yandex.com
15332 [2021-10-26 21:32:02.385] [metadataExpiration] [info] Scanning for expired metadata
15332 [2021-10-26 21:32:02.385] [metadataExpiration] [info] -- Will wake for next expiration in 7200sec
15332 [2021-10-26 21:32:02.486] [background] [warning] [SLOW] Transaction=markAllFoldersBusy > 80ms (381ms, 379 waiting to aquire)
15332 [2021-10-26 21:32:02.486] [background] [info] Syncing folder list...
15332 [2021-10-26 21:32:05.109] [main] [info] Waking all workers...
15332 [2021-10-26 21:32:05.109] [metadata] [info] Metadata delta stream starting...
15332 [2021-10-26 21:32:06.132] [metadataExpiration] [info] Scanning for expired metadata
15332 [2021-10-26 21:32:06.132] [metadataExpiration] [info] -- Will wake for next expiration in 7200sec
15332 [2021-10-26 21:32:08.121] [main] [info] Waking all workers...
15332 [2021-10-26 21:32:08.756] [foreground] [info] syncFolderUIDRange for INBOX, UIDs: 1 - 24, Heavy: false
15332 [2021-10-26 21:32:09.046] [background] [info] syncFolderUIDRange for INBOX, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:09.141] [metadataExpiration] [info] Scanning for expired metadata
15332 [2021-10-26 21:32:09.141] [metadataExpiration] [info] -- Will wake for next expiration in 7200sec
15332 [2021-10-26 21:32:09.143] [foreground] [info] - remote=0, local=0
15332 [2021-10-26 21:32:09.160] [foreground] [info] Idling on folder INBOX
15332 [2021-10-26 21:32:09.433] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:09.688] [background] [info] syncFolderUIDRange for Sent, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:10.074] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:10.328] [background] [info] syncFolderUIDRange for Drafts, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:10.706] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:10.951] [background] [info] syncFolderUIDRange for Trash, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:11.491] [background] [info] - remote=10, local=10
15332 [2021-10-26 21:32:11.749] [background] [info] syncFolderUIDRange for Spam, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:12.138] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:12.396] [background] [info] syncFolderUIDRange for Mailspring, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:12.768] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:13.021] [background] [info] syncFolderUIDRange for Mailspring|Snoozed, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:13.400] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:13.653] [background] [info] syncFolderUIDRange for Outbox, UIDs: 1 - 0, Heavy: false
15332 [2021-10-26 21:32:14.034] [background] [info] - remote=0, local=0
15332 [2021-10-26 21:32:14.035] [background] [info] Sync loop deleting unlinked messages with phase 1.
15332 [2021-10-26 21:32:14.035] [background] [info] Sync loop complete.
