I think the reason is that it Mailspring doesn’t support proxy now.
I checked dev console in Mailspring, it shows:
FetchError: request to https://www.googleapis.com/oauth2/v4/token failed, reason: Client network socket disconnected before secure TLS connection was established
at ClientRequest.<anonymous> (/Applications/Mailspring.app/Contents/Resources/app.asar/node_modules/node-fetch/lib/index.js:1501:11)
at ClientRequest.emit (node:events:518:28)
at ClientRequest.emit (node:domain:488:12)
at TLSSocket.socketErrorListener (node:_http_client:495:9)
at TLSSocket.emit (node:events:518:28)
at TLSSocket.emit (node:domain:488:12)
at emitErrorNT (node:internal/streams/destroy:169:8)
at emitErrorCloseNT (node:internal/streams/destroy:128:3)
at processTicksAndRejections (node:internal/process/task_queues:82:21)
