Ctrl+q closes program instead of marking mail as read with Outlook shortcuts
Control+q causes Mailspring to close instead of mark mail as read with Outlook shortcuts. Other Outlook shortcuts work as expected (eg. ctrl+u marks as unread).
I have checked the logs (eg. “user\AppData\Roaming\Mailspring\mailsync-f50f4c66.log”) and there seems to be no evidence of the program either closing gracefully or an exception.
I can try running it with debug flags but it requires me to log into my accounts again. Let me know if necessary
  1. Set keyboard shortcuts to Outlook
  2. Mark message as unread with ctrl+q
Mail should be marked as read
  • OS and Version: Windows 10 2004
  • Mailspring Version: 1.7.8
Is it possibly to do with the Outlook template still using “ctrl” instead of “mod” in the keymap json here: Mailspring/Outlook.json at 4b6c24fefa270d29ee5733d66f0885aae4e6e4e1 · Foundry376/Mailspring · GitHub?
 "core:focus-item": "ctrl+o",
  "core:mark-as-read": "ctrl+q",
  "core:mark-as-unread": "ctrl+u",
  "core:star-item": "ctrl+shift+g",
Should all be changed I think
(Originally posted by fionnan-r on GitHub.)
My guess is that this is a MacOS shortcut that’s unintentionally taking effect on Windows too.
Apps on MacOS use Cmd+Q to quit. Since non-MacOS platforms generally don’t have a Cmdkey, cross-platform apps usually swap Cmd for Ctrl on non-MacOS platforms.
Duplicate(s):
That sounds like you found the issue.
But when get it fixed? Do you know that?
Because this topic is now open a while and when the cmd is simply mapped to ctrl then Mailspring should also have an Application close section in the shortcuts settings.
In this way I could overwrite it i.e. to Ctrl+W on Windows/Linux.
so it’s not 2026 and you still haven’t figured it out?
I have it mapped as CTRL+Q to mark as read, but it still just exit the app… not the end of the world but … annoying af
