mail.google.com itself allows you to specify colors for different labels/tags.
After years of using the same colors, it’s a little odd to see the same emails with different colors in Mailspring.
How are you generating these folder/label colors? Is there any way to pull the colors directly from Gmail? I understand if this information simply is not available, but I’m interested to understand the current process either way.
would be a really helpful enhancement seeing same labelcolors in Mailspring. We also use the same colorcode for a while now and every teammember is used to them. Seeing different colors in Mailspring is really a little weird.
If it’s not possible to pull the colors from gmail, why not make a Settings option where you can choose a color? This way, you can at least match it on your own.
But this is probably another thing, so should I open a new issue for this?
Following up on @evoxxgithub and @ipolevoy… Two years later this seems like a huge benefit for a mail client that does care about aesthetics. For some of us, colour is a key part of organization. Is the not-yet-possible tag added because the feature was not added or because it is not yet possible to add a color-picker feature?
Being able to add colors to labels is a fundamentally feature for mail organization. I just started using Mailspring and not being able to change the colors of labels is a big problem. My whole workflow is being thrown off. Please consider a feature to change the color of labels!!
I think we could reasonably accept a pull request, or at least a plugin, for a color picker feature, depending on how it was implemented into the interface. (Actually, you’d build it the same anyway whether as a built-in core plugin or an external plugin.) We don’t want to clog the interface up with too many options, but this seems like a fairly elementary use case.
Being a linux user, I’m very much used to having complete control of even the most minute settings to make my life more efficient by using automation (which is the entire purpose of computers).
It is really hard to identify which category each mail belongs to; all of the chosen label colours look almost identical. Additionally being a gmail user and having granular control of the colour we use for each label, has gotten me used to a specific colour for each label.
Allow us to choose the colour of each label manually so that we can match the colours we have in the gmail interface.
Alternative Solutions
Sync the label colour to gmail automatically.
I used to believe that Mailbird was the best client to use with gmail, BUT Mailbird is not available for linux, which was a bummer. But then looking for an alternative to Mailbird for linux, I came across a few clients that could work with gmail labels and found that Mailspring came the closest to mimicking gmail’s labels as a linux email client and actually I now think that Mailspring is BETTER than Mailbird for gmail, however it is still lacking this core feature of label colour customization.
I believe this affects ORGANIZATION and PRODUCTIVITY greatly therefore, I kindly urge the developers to prioritize this solution.
I wanted to add my voice to the existing requests for the ability to customize label colors within Mailspring. A simple color picker when creating or editing a label would go a long way. I hope there is a timeline to make this improvement.
