Title: Dark Mode Inversion Issue: Custom Dark Hex Colors (#111827) Render Illegible on Dark Background
Body:
I encounter a rendering issue when using Mailspring in Dark Mode. When an HTML email (specifically an email signature) uses specific dark hex codes for text (e.g.,
#111827
, a very dark grey), Mailspring’s dark mode engine fails to invert the lightness of these colors effectively.
Instead of flipping the dark text to a light color (as it does with standard black), it seems to treat it as a “colored” element and creates a low-contrast dark-blue-on-dark-grey result, rendering the text nearly invisible.
Steps to Reproduce
Enable Dark Mode in Mailspring.
Receive or Compose an email containing HTML with text styled as
color: #111827;(or similar dark charcoals).
Observe the rendering.
Modern dark mode algorithms (like those in WebKit or other mail clients) typically detect when a text color’s luminosity is too close to the dark background and invert it to a high-contrast light shade (e.g., shifting
#111827
to a soft white or light grey).
Actual Behavior
The background turns dark grey, but the text remains very dark (appearing as a low-visibility dark blue/black), making it illegible against the dark background.
Environment
OS: Linux / Mac
Mailspring Version: (Insert your version here, e.g., 1.13.3)
Technical Suggestion
The issue appears to be that the inversion algorithm is too conservative with “colored” pixels. Dark Greys like
#111827
are technically colors (Blue-Grey), which might be bypassing the standard “Black-to-White” inversion. Adjusting the threshold for what constitutes “black text” or forcing a minimum contrast ratio against the background would solve this.
