I would like to be able to rearrange icons on the toolbar, delete one or two also.
Make toolbar editable.
Hiding buttons should be fairly easy, if you’re happy editing a theme. If you add the display: none property on any of the buttons, they’ll not be shown. I’m not sure what that’ll do to the layout, but it’s probably worth a try!
Rearranging them is a bigger ask, I think, but might be addressable through a theme as well (depending how the css is structured). I agree it’d be a nice feature, though!
