Problem
Some Folders seem to stuck while Synchronization
The Log shows this errors and repeats it.
2278531 [2022-09-12 14:45:10.400] [metadata] [info] Metadata sync disabled, not logged in.
2250052 [2022-09-12 14:45:13.171] [background] [info] Syncing folder list...
2250052 [2022-09-12 14:45:13.756] [background] [info] syncFolderUIDRange for INBOX, UIDs: 1 - 32571, Heavy: false
2278531 [2022-09-12 14:45:14.400] [background] [info] Marking all folders as `busy`
2278531 [2022-09-12 14:45:14.410] [background] [info] Syncing folder list...
2278531 [2022-09-12 14:45:15.177] [background] [info] Syncing folder list...
2278531 [2022-09-12 14:45:15.370] [background] [info] syncFolderUIDRange for INBOX, UIDs: 1 - 32571, Heavy: false
2278531 [2022-09-12 14:45:15.856] [background] [info] - INBOX: remote=3497, local=1, remoteUID=sb14uypSAAnrBLTXg5BrVM1mrxV4MTeRJjCoH1rFD
2278531 [2022-09-12 14:45:15.867] [background] [info] - Fetching full headers for 3496 (of 3496 needed)
2278531 [2022-09-12 14:45:16.069] [foreground] [info] syncFolderUIDRange for INBOX, UIDs: 32972 - 33346, Heavy: false
2278531 [2022-09-12 14:45:16.282] [foreground] [info] - INBOX: remote=101, local=101, remoteUID=sb14uypSAAnrBLTXg5BrVM1mrxV4MTeRJjCoH1rFD
2278531 [2022-09-12 14:45:16.283] [foreground] [info] Connection does not support idling. Locking until more to do...
2278531 [2022-09-12 14:45:16.737] [background] [critical]
*** {"debuginfo":"syncFolderUIDRange - fetchMessagesByUID (heavy)","key":"ErrorParse","retryable":true,"what":"std::exception"}
2278531 [2022-09-12 14:45:16.738] [background] [critical] *** Stack trace (line numbers are approximate):
*** ??:? SyncWorker::syncFolderUIDRange(Folder&, mailcore::Range, bool, vector*)
*** ??:? SyncWorker::syncNow()
*** ??:? runBackgroundSyncWorker()
*** main.cpp:? main::{lambda()#3}::operator()() const
*** main.cpp:? _Bind_simple::operator()()
*** main.cpp:? thread::_Impl::_M_run()
*** thread.o:? execute_native_thread_routine()
2278531 [2022-09-12 14:45:16.738] [background] [info] --sleeping
2278531 [2022-09-12 14:45:25.399] [metadataExpiration] [info] Scanning for expired metadata
2278531 [2022-09-12 14:45:25.399] [metadataExpiration] [info] -- Will wake for next expiration in 7200sec
Email Provider
IMAP IBM Notes 10
- OS and Version: Ubuntu 20.04.4 LTS (Focal Fossa)
- Installation Method:.deb
- Mailspring Version: 1.10.5-1ce06f18
