I have lots of threads with a dozen or more messages. When I run a search, the results list displays threads, not individual messages. If I highlight a thread, the reading pane doesn’t show the message containing the search term, but instead (usually) has the newest message in the thread expanded. If I expand all, there is no highlighting of the search term (that I can see).
How does one find the actual relevant part of a long thread in search results?
The mailbox search works at the conversation level: results are threads, and opening one expands the usual messages (unread ones plus the newest), not necessarily the one that matched. The tool for the second step is Find in thread: with the conversation open, press Cmd+F on Mac or Ctrl+F on Windows/Linux (Ctrl+Shift+F or F4 if you use the Outlook shortcut set), type the term, and Mailspring expands every message in the thread and highlights each hit. Enter / Shift+Enter (or Cmd/Ctrl+G and Cmd/Ctrl+Shift+G) jump to the next and previous match, so in a 30-message thread you land right on the sentence.
