Freeze when in composition mode
Mailspring freezes and only intermittently works once I have started a reply in any account. I can type a couple letters out but then it beachballs. It’ll catch up maybe 30-60 seconds later, but then typing again causes beachballing again. CPU and GPU usage never seem super high (Mailspring Helper GPU and Mailspring default usually only average around 5-8% each when this is happening) but it’s definitely stuck. If I go to perform other actions while that composition is still in flight, like clicking an unrelated message for example, it’s still very much in the frozen/beachballing state, with super slow response times. Eventually, I get the following:
  1. Open an email thread
  2. Begin a reply
  3. Start typing
  4. After a few keystrokes, Mailspring freezes for a while.
This also happens with a new composition window as well.
For typing to be a non-issue. :slight_smile:
Mailspring 1.15.1
macOS Sequoia 15.4.1
Note that I also completely removed Mailspring, and all associated Library files, etc. (using AppCleaner) and reinstalled/re-setup up from scratch. Exact same behavior, which I was surprised by.
I’ve got 2 Gmail accounts, 2 Outlook accounts, and 1 Fastmail account.
