Gmail connection issue
Problem
I’m unable to connect to Gmail accounts, other services seems to work well (I only tried Outlook, it work).
Screenshot :
https://drive.google.com/file/d/1cBNLJZFs4oadPLQ2uStn7PKIPqsq14dP/view?usp=sharing
https://drive.google.com/file/d/1Ukpr6l9-bHu-GThWUp4UPxLGkbL-nE4U/view?usp=sharing
Tried on two differents account, one Google Workplace account, and one Personnal account, same result on both.
Email Provider
Gmail
Tried on multiple devices, same result:
  • OS and Version: Ubuntu 22.04
  • Installation Method: .deb
  • Mailspring Version: 1.10.3
  • OS and Version: Windows 11
  • Installation Method: installer
Find the issue, it was my fault ^^’
The issue was cause by a chrome extension I’m using : https://docs.clearurls.xyz/
Disabling it fix the issues.
The weird thing being that other services using Google SSO work even with the extension enable, didnt look more into it.
