Trying to type a reply to an email, and hotkeys keep triggering. This becomes downright dangerous as I could do unintended things to the message I’m replying to.
Open an Email
Click “reply”
Start typing any letters that are also assigned to hotkeys
Watch those commands execute instead of the letters being typed in the reply dialogue.
Letters appearing in the reply dialogue
Difficult to screenshot as it would just show a hot key being triggered.
Windows 11, installed via update from existing version. Version 1.20.0-58895290
Fully agree. I had to revert to the last version and ignore the update prompt. You can find previous versions on their Github, as a workaround, for now. I just went back one version and it fixed the issue for me. Then definitely don’t update untill this has been addressed.
This was a regression introduced in v1.20.0 that caused keyboard events to leak through from the composer into the global keymap. It has been fixed — please update to v1.21.0 or v1.21.1 (the latest release as of May 19, 2026) and all keyboard behavior should be back to normal. Apologies for the disruption!
