I am using a single gmail account with Mailspring. When I click on “archive” on an item that is in a folder (tag) it does not disappear. I can’t tell what the archive button is supposed to do.
Archive in Mailspring means exactly what it means in Gmail: take the conversation out of the Inbox and nothing else. It removes the Inbox label; the message stays in All Mail and keeps every other label it has. When you’re looking at a label and click Archive, the thread was never “in” the inbox from that view’s point of view — it just loses its inbox label (if it had one) and stays put in the label you’re viewing. That’s the behavior you’re seeing, and it’s the same as clicking Archive inside a label in Gmail’s web UI.
To take a conversation out of a label, remove the label instead:
- Press Backspace or Delete (or y if you use the Gmail shortcut set) while viewing the label — that removes the label you’re in and the inbox label in one go, so it disappears from the list.
- Or click the x on the label chip in the thread, or use the label picker in the toolbar to untick it.
(If you’d rather Backspace send things to the trash, there’s a “Move to trash (not archive) on swipe / backspace” option in Preferences > General.)
