I’m still trying to figure out how to properly set up my dev environment to contribute to Mailspring. I still haven’t figured out how to run the unit tests.
I was initially hitting this error:
[12736:0327/101055.732:INFO:CONSOLE(26)] "Error: Could not find a file at path '../../static/jasmine'
at ThemeManager.requireStylesheet (file:///C:/src/Mailspring/app/src/theme-manager.ts:163:13)
at SpecRunner._setupAppEnv (file:///C:/src/Mailspring/app/spec/spec-runner/spec-runner.ts:118:19)
It looks like the path is actually static/style/jasmine so I modified that:
--- a/app/spec/spec-runner/spec-runner.ts
+++ b/app/spec/spec-runner/spec-runner.ts
@@ -115,7 +115,7 @@ class SpecRunner {
AppEnv.restoreWindowDimensions();
AppEnv.themes.loadStaticStylesheets();
- AppEnv.themes.requireStylesheet('../../static/jasmine');
+ AppEnv.themes.requireStylesheet('../../static/style/jasmine');
AppEnv.themes.initialLoadComplete = true;
AppEnv.keymaps.loadKeymaps();
After that, I tried./node_modules/.bin/electron ./app --enable-logging --test again, and a blank Electron window popped up, along with dozens of cmd windows that didn’t seem to be doing anything
Am I missing something? Where are the test results supposed to appear?
I looked in .travis.yml to see how the tests are configured for CI builds, and it seems like Travis doesn’t actually run the tests
Would you be open to using Jest for the tests instead of Jasmine (at least, for new tests)?
