Authentication failed when connecting to SMTP server. When I look to log file, I see that incorrect Auth string is send.
----------SMTP----------
connect mail.egate.cz 587
220 eGate SMTP
init
EHLO matla-ntb
250-mail.egate.cz
250-SIZE 102400000
250-STARTTLS
250-AUTH LOGIN PLAIN
250 HELP
start TLS
STARTTLS
220 Ready to start TLS
done
OpenSSL version: OpenSSL 1.1.0f 25 May 2017
init after starttls
EHLO matla-ntb
250-mail.egate.cz
250-SIZE 102400000
250 HELP
AUTH PLAIN YWRhbS5tYXRsQGRlc28uY3oAYWRhbS5tYXRsQGRlc28uY3oAY2Vuc29yZWQ=
535 Authentication failed. Restarting authentication process.
SASL_PATH: /usr/share/mailspring/resources/app.asar.unpacked
SMTP Last Response Code: 535
SMTP Last Response: Authentication failed. Restarting authentication process.
mailsmtp Last Error Code: 17
mailsmtp Last Error Explanation: MAILSMTP_ERROR_AUTH_LOGIN
mailsmtp Last Auth Type: 2
Decoded AUTH PLAIN string
adam.matl@deso.cz\0adam.matl@deso.cz\0censored
there is username two times
When I try to connect with OpenSSL and correct auth string, it is OK.
openssl s_client -crlf -connect mail.egate.cz:465
read R BLOCK
220 eGate SMTP
EHLO mail.egate.cz
250-mail.egate.cz
250-SIZE 102400000
250 HELP
AUTH PLAIN AGFkYW0ubWF0bEBkZXNvLmN6AGNlbnNvcmVk
235 authenticated.
- File->Add new account
- IMAP/SMTL
Fill credentials
click continue
fill settings
click connect account
result
Connection to account
- OS and Version: Ubuntu 21.04
- Installation Method: .deb
- Mailspring Version: 1.9.2-6e14dad1
