Installation/running issues on Debian stable (.deb, snap)
I installed mailspring using the .deb on Parrot OS (debian stable). It starts, but later failed when I authenticated with my mailspring login, because no keyring was found. Both, thee kwallet and gnome-keyring are installed and running; I also tried passing different kwallet parameters; no way to get it running.
Then I installed the snap as root. /usr/bin/mailspring not found. I installed as a user. The same.
Very frustrating.
