Installed Mailspring but can't read emails
Just installed Mailspring on my Zorin 18 system. All my email folders show up but I can’t read any email just an error message:
ReferenceError: localized is not defined
at ThreadList.render (/app/share/mailspring/resources/app.asar/internal_packages/thread-list/lib/thread-list.js:168:482)
at Mh (/app/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:173:192)
at Lh (/app/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:172:282)
at mj (/app/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:247:361)
at jj (/app/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:216:164)
at Z (/app/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:210:471)
at $i (/app/share/mailspring/resources/app.asar/node_modules/react-dom/cjs/react-dom.production.min.js:206:372)
Any ideas for me to try?
Hi @Daiv727 thanks for reporting this, sorry you’ve run into issues getting the app to start. This should be resolved by the 1.19.1 release which shipped yesterday - if you want to give that version a shot I think that it’ll run properly for you. You can download the update from Mailspring - The best free email app or via snap refresh mailspring if you’re using the Snap build.
trying to find 1.19.1 release. 1.20 broke my space bar usage in editing reply
here: Release 1.19.1 · Foundry376/Mailspring · GitHub
Hy @daelv thanks for the reply - can you clarify your spacebar usage? Sounds like a key mapping maybe?
Ben
