I have just noticed that the following keyboard shortcuts are not working on Mailspring 1.10.5-1ce06f18 on Linux.
Not working shortcuts
These shorcuts should work, however, they might have been deprecated and removed in a previous version of Mailspring:
navigation:go-to-contacts;navigation:go-to-label;navigation:go-to-tasks;window:reload;application:show-main-window[Window → Message Viewer (Ctrl+0)];- F10 nor Alt+$letter, but pressing and releasing Alt selects
File, then Space or Down opens the menu. While the menu is open, Right and Left arrows won’t change the selected menu, but I need to press Esc, move Left or Right and open the menu again using Space or Down; - Esc when I open preferences (? or Ctrl+, or Edit → Preferences), Esc does not close them unless I click anywhere (on a tab or an empty space/background);
“application:open-help”: “w”, // This does not work, whatever is the shortcut
“core:show-keybindings”: “mod+shift+,”, // This always works with ?, but even when changed, it always works on ? application:more-actions;core:change-category;core:pop-sheet(also in here; in GUI, it is namedReturn to conversation list) does not work, at least when I use two-panel layout:- when I open (using keyboard shortcut or mouse-click) a message (email), when I press Esc or U, it does not close the email (i.e. the reading pane should be blank).
Suggestions
Add the following keyboard shortcuts (I believe they are self-explanatory):
navigation:go-to-unread(possible Google-inspired shortcut could beg u);navigation:go-to-snoozed(possible Google-inspired shortcut could beg z);navigation:go-to-reminders(possible Google-inspired shortcut could beg r);navigation:go-to-important(possible Google-inspired shortcut could beg !");navigation:go-to-trash(possible Google-inspired shortcut could beg b);
navigation:go-to-activity(view current account Activity; possible Google-inspired shortcut could beg v);???(open Activity menu with rolling box; possible shortcut could bev);core:focus-item-new-window(open selected message in new window; possible shortcut could be eitherShift+oorShift+Enter).
- Although comments are (were?) allowed in
keymap.json, but only on separate lines. When they are placed after on the same line as the key-value pair (e.g."key": "value" // some comment, regardless if there is a comma after the value and its quote), Mailspring ignores that particular keyboard shortcut definition (i.e. entire line).
