kazrude
(Kaz)
1
Basically every time I archive something it gets stuck/delayed. That was not the case before the recent update.
Phylu
(Janosch Braukmann)
2
Can you please clarify on the issue?
- Where does this happen? Is it from the normal e-mails view in the main UI? Your screencast somehow looks like you are doing this in a notification.
- Which OS are you using?
- Which mailspring version is affected?
Do you see any errors in the UI logs?
- Go to “Developer” > “Toggle Developer Tools”
- Chose the “Console” tab
- Press “Clear Console” (Ctrl + L)
- Reproduce the Issue
- Do a right click inside the console and click “Save as”
- Clear any personal information from the debug file that you now have created
- Attach the file here
Do you see any errors in the mailsyn logs?
- Go to your Mailspring User Directory:
- Mac:
~/Library/Application Support/Mailspring
- Windows:
C:\Users\<Your User>\AppData\Roaming\Mailspring
- Linux:
$XDG_CONFIG_HOME/Mailspring or ~/.config/Mailspring
- Look for the file
mailsync-xxxxxxxx.log wheras the xxxxxxxx denote the internal id of your e-mail account
kazrude
(Kaz)
3
- Happens in the main list
- OS is macOS Ventura 13.5.2 (22G91)
- Mailspring version is Version 1.13.1 (1.13.1)
DevTools log is here -1700843108796.log (580 Bytes)
No errors in logs.
