Mails not showing up - with different address
Hi,
i have 2 accounts for gmx. gmx.com and gmx.de.
I forward all my mails from gmx.de to the gmx.com account and it works great. But Mailspring doesnt show these Mails. I tried an Alias but it didnt work.
Even another Alias i use for the gmx.com account with an gmx.com ending isnt showing up consistently after adding it to the alias.
What can i do?
Thank you!
on another topic: I also would like one inbox for all my address (including another gmail.com account but i dont know yet how to do it.)
Aliases in Mailspring only affect sending — they add extra “From” addresses you can pick in the composer. They don’t pull in any mail, so adding gmx.de as an alias on the gmx.com account won’t make the forwarded messages appear; that’s expected.
The forwarded mail should simply show up in the gmx.com account like any other message, so if it isn’t, the question is where GMX is putting it. Log in to GMX webmail and find one of the forwarded messages: if it’s in the Inbox there, press F5 in Mailspring (File > Sync New Mail Now) and check the sync progress at the bottom of the sidebar; if GMX has filed it into another folder or Spam, that’s where it’ll be in Mailspring too, and you’d fix that with a GMX filter rule rather than anything on our side.
For the one-inbox question: just add the Gmail account in Preferences > Accounts. With more than one account connected, the sidebar shows All Accounts at the top with a single combined Inbox — pick that (or Ctrl+1 / Cmd+1) and you’ll see everything together: Setting up multiple accounts — Mailspring Documentation
