Mailspring 1.17.3 issues
Here’s my hardware specs & software versions:
Operating System: Fedora Linux 43
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.22.0
Qt Version: 6.10.1
Kernel Version: 6.18.6-200.fc43.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 7840U w/ Radeon 780M Graphics
Memory: 32 GiB of RAM (30.6 GiB usable)
Graphics Processor: AMD Radeon 780M Graphics
Manufacturer: Framework
Product Name: Laptop 13 (AMD Ryzen 7040Series)
System Version: A7
And, here’s what I get when I try to run Mailspring:
~mailspring --trace-deprecationon
Running database migrations
App load time: 216ms
/usr/share/mailspring/resources/app.asar.unpacked/mailsync.bin: /lib64/libcurl.so.4: no version information available (required by /usr/share/mailspring/resources/app.asar.unpacked/mailsync.bin)
{“error”:null}
[764031:0205/123042.103196:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:273] Unable to set image transfer function.
[764031:0205/123042.103213:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:191] Failed to populate image description for color space {primaries:BT709, transfer:SRGB, matrix:RGB, range:FULL}
[764031:0205/123042.105067:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:273] Unable to set image transfer function.
[764031:0205/123042.105081:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:191] Failed to populate image description for color space {primaries:BT709, transfer:SRGB, matrix:RGB, range:FULL}
Manual update check (updates.getmailspring.com/check/linux/x64/1.17.3-6978bdc7/01b63939-8b90-49ca-a39a-df395a72049b/stable) returned 204
[764031:0205/123042.468805:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:273] Unable to set image transfer function.
[764031:0205/123042.468825:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:191] Failed to populate image description for color space {primaries:BT709, transfer:SRGB, matrix:RGB, range:FULL}
(node:764031) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
at asarStatsToFsStats (node:electron/js2c/node_init:2:1796)
at Object.t.lstatSync (node:electron/js2c/node_init:2:4883)
at Object.t.statSync (node:electron/js2c/node_init:2:5445)
at Object.fs.statSyncNoException (/usr/share/mailspring/resources/app.asar/src/browser/main.js:9:24)
at Function. (file:///tmp/nylas-build/electron-packager/tmp-IsLJGN/resources/app/src/browser/mailspring-protocol-handler.ts:38:30)
Hey folks - Mailspring 1.17.4 is now available and includes fixes that should address the issues you’re seeing. Specifically: the Wayland color management / window activation issue has been fixed (#2599), and RPM packaging dependencies have been updated for Fedora 43 and openSUSE compatibility (#2590). The libcurl version warning should also be resolved. Please try updating and let us know how it goes.
