Whenever I open an attachment (e.g. a PDF) from an email, after several seconds I get an pop-up saying:
Mailspring is not responding. Would you like to force close it or keep waiting?
- Open an email with some attachment
- Open the attachment
- Wait…
Not getting a pop-up that says Mailspring is not responding, as I’m just having an attachment open.
See here
- OS and Version: Linux Fedora 35 with Sway as window manager.
- Installation Method: From .rpm on the website
- Mailspring Version: 1.10.2 - 69a03d6d
Log messages (I don’t get any new log message when the pop-up appears):
Running database migrations
App load time: 194ms
{"error":null}
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[169416:0411/111239.738933:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
(node:169379) electron: The default of nativeWindowOpen is deprecated and will be changing from false to true in Electron 15. See https://github.com/electron/electron/issues/28511 for more information.
(Use `mailspring --trace-warnings ...` to show where the warning was created)
Manual update check (updates.getmailspring.com/check/linux/x64/1.10.2-69a03d6d/9e591a04-c8ad-4985-a52a-c07aa029ad9b/stable) returned 504
Error Downloading Update: Unexpected end of JSON input
(mailspring:169379): IBUS-WARNING **: 11:12:41.115: Unable to connect to ibus: Could not connect: Connection refused
