Mailspring Offline Translator lets you translate incoming emails and drafts directly in Mailspring. Translations run on your device, so email content is not sent to a cloud translation service. Mozilla/Translations models require an initial download; once installed, translation works offline.
Features
- Translate received messages and switch between the original and translated text, with inline or side-by-side views.
- Translate email drafts, preview the result, and apply it only after confirmation.
- Choose an available on-device engine: Apple Translation on macOS 26 or later, Edge Translator on Windows, or Mozilla/Translations on macOS, Windows, and Linux.
- Preserve message layout and links, with options to exclude quoted replies, signatures, and code blocks.
- Manage language models and clear the local translation cache from Mailspring Preferences.
- Download the latest
.zipfrom GitHub Releases. - Extract the
mailspring-offline-translatorfolder into Mailspring’spackagesdirectory:- macOS:
~/Library/Application Support/Mailspring/packages - Windows:
%APPDATA%\Mailspring\packages - Linux:
~/.config/Mailspring/packages
- macOS:
- Restart Mailspring and open Preferences > Offline Translator > Offline Models to install the language models you need. Model downloads require an internet connection; translation runs locally afterward.
Getting Help
Report bugs or request features using the GitHub issue templates. You can also browse existing issues.
