Hello, I started under windows, but I kept reporting node errors. I tried many methods on the Internet, but they haven’t been solved. How should I solve this
How did you install Mailspring? What veresion are you running? And what version of Windows are you using?
I ask because the error says there’s a problem with the better-sqlite3 module - your system is trying to run Mailspring with a different version than the one it was built to use. And that suggests there’s a problem with your Mailspring package. Did you compile it yourself or use the pre-built installer?
