hi, I’ve been using mailspring for about 2 yrs. It’s worked fine, a little buggy at first but it’s gotten better and better and more stable the more I’ve used it. I open and use it daily. I just opened it about 7 hrs ago and as usual it opened fine. Went to sleep, got up now and suddenly it wouldn’t open. I tried restarting and again it wouldn’t open. So I tried to reinstall it and it won’t install either. I’m using windows 7
I pasted some of the info from the setup log … and attached the whole setup log. Thanks for any help or tips in advance. I appreciate it, Rey
2022-06-12 00:49:15> Program: Starting Squirrel Updater: --install .
2022-06-12 00:49:15> Program: Starting install, writing to C:\Users\dude\AppData\Local\SquirrelTemp
2022-06-12 00:49:15> Program: About to install to: C:\Users\dude\AppData\Local\Mailspring
2022-06-12 00:49:15> CheckForUpdateImpl: Couldn’t write out staging user ID, this user probably shouldn’t get beta anything: System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\dude\AppData\Local\Mailspring\packages.betaId’.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
SquirrelSetup.log (69.3 KB)
