Update to v1.21.1: The v1.20.0–v1.21.0 updates included fixes preventing global keyboard shortcuts from firing inside the composer. It’s possible the Enter key (or another shortcut) was triggering send. Please update to v1.21.1 (released May 19, 2026) and see if the issue recurs.
Check your send shortcut: Go to Preferences > Shortcuts and confirm the send shortcut is set to Ctrl+Enter (not just Enter). If “Enter” alone is mapped to send, that could explain accidental sends while typing.
If it happens again after updating, please note the exact key sequence you were typing when the send occurred — that will help us narrow it down.
