Mialspring will not launch the GUI on Debian 13 with KDE Plasma 6 (Wayland)
When starting Mailspring 1.17.x, the application does not render its GUI when launched under KDE Plasma 6 (Wayland). The app icon appears in the task manager, and logs show that the app loads and runs internally, but no visible window is rendered. Two workarounds include downgrading to Mailspring 1.16.0 and that resolves the issue or using X11 instead of Wayland. This appears to be related to Wayland + NVIDIA GBM behavior in newer Electron versions used by Mailspring 17.x.
  1. Log into KDE Plasma 6 using Wayland.
  2. Launch Mailspring 1.17 via terminal or menu; No GUI is rendered, but icon appears in taskbar.
  3. Right click on the icon in the taskbar click “Quit Mailspring”, then int he terminal run “mailspring --disable-gpu --enable-logging”.
Mailspring should open a usable window with its full GUI. Instead, only the icon appears, and the GUI is invisible or never mapped.
Terminal Output (partial):
src/nv_gbm.c:288: GBM-DRV error (nv_gbm_create_device_native): nv_common_gbm_create_device failed (ret=-1)
[WARNING] Binding to wl_seat version 8 but version 9 is available
[WARNING] Server doesn’t support zcr_alpha_compositing_v1
Gtk-Message: Failed to load module “appmenu-gtk-module”: undefined symbol: gtk_module_display_init
[INFO] Window load time: 286ms
[ERROR] crypto/nss_util.cc:346 After loading Root Certs, loaded==false: NSS error code: -8018
-OS: Debian 13 “Trixie”
-Kernel: 6.18.8-1-liquorix-amd64
-Desktop: KDE Plasma 6.3.6 (Wayland)
-GPU: NVIDIA RTX 3050 Ti Mobile (w/ Intel UHD hybrid graphics)
-Display Server: Wayland (KWin)
-Mailspring Version: 1.17.3
    • Installation Method: Installed via .deb package “mailspring-1.17.3-amd64.deb”
  • Mailspring Version: 1.17.3
Mailspring 1.16.0 works correctly on this same system and under Wayland. The issue began in 1.17.0 and persists through 1.17.3. but with KDE pushing Wayland more it might become a bigger issue later.
There seems to be a problem with wayland currently, that can be temporarily avoided when launched with this option :
–ozone-platform=x11
there is a double - at the beginning I can’t get it right
Okay I will give that a try. Thank you.
Hey folks - Version 1.17.4 was just released and includes a fix for Wayland window activation (#2599) that should address this issue. The app now handles the Wayland activation context gracefully, so the GUI should render properly without needing --ozone-platform=x11. Please try updating to 1.17.4 and report back whether this resolves the problem on your Debian 13 + KDE Plasma 6 setup.
I logged out, switched to Wayland and yes it seems to working great now with the new update. Thank you for fixing this.
This Wayland issue was fixed in v1.17.4. Please update to v1.21.1 (the latest) — if you’re still experiencing window display issues on Wayland with a current version, the workaround --ozone-platform=x11 in your launcher still applies as a fallback. Let us know if you see any further Wayland-specific problems.
