More than 5 mailbox displayed on left side panel
Hi, I can’t see more than 5 mailbox in the left side panel
  1. 5 by default. to see more :
  2. Click on one of the 5 account
  3. After Click on all account
  4. Now i see my 6 accounts left side
All account directly visible
Latest version in windows 11
got something like this,
at startup left panel only shows 3 accounts on 5,
i have to re-select “all accounts” to get the 5.
this could be considered a minor issue BUT the this affects synchronization : new messsages on hidden accounts are missing and no notifications occurs.
OK, i think i found the real bug.
mailspring does not save the current display settings until you actualy quit it.
accounts list in the left panel only displays the accounts that were displayed last time you quitted the app for real. shutting down computer with mailspring running in background is not enough.
So select “all accounts”, quit mailspring, restart mailspring, done :slight_smile:
