Moving messages between accounts
I tried Mailspring some years ago and for some reason, wasn’t happy with it. Now I am trying it again, I suspect I have found out what made me unhappy last time; it doesn’t appear to be possible to move messages from one account to another. Is this the case? If I’m wrong, how do I do it?
Yes, same reason I abandoned it. I just returned to the platform but see that it doesn’t have this listed in Shortcuts. I mean… it’s got everything and the kitchen sink — except this simple shortcut.
@xenos-github @gospaboy you will find this feature suggestion at the following link. If you would like to see this feature implemented, you may vote for it.
Moving emails between IMAP accounts isn’t directly supported (IMAP mailboxes are separate stores with no protocol-level “move between accounts” operation).
Workaround: Right-click a message > Export as EML (added in v1.20.0), then in the destination account, import the EML file by dragging it into Mailspring. It works for individual messages, though it’s not seamless for bulk operations.
